Bleeding Elm
Hollands
Took a branch off of an elm over a year ago. At the time i noticed that it was bleeding a bit, but thought it would stop once it came into full leaf. I pruned the rest of the tree aswell, but only this one wound bled. It is now a year later and it is still bleeding. I'm pretty sure its just water that is coming out, doesnt look sappy. Will this stop or do i need to remove the entire branch back to the main stem. The tree has just lost its leaves.:confused1:
put a plaster on it lol hazard a guess at bacterial wetwood when that gets into pops they tend to ooze a little gas and liquid but this is usuall on the main trunk i think and comes with some smell and cakey limey residue around the wound is there any residue around the wound ? .... this is a wild guess by the way
If the tree isnt showing physiological signs of stress...and remember, you are only getting a snap shot of the process I presume ( seen it twice in a year..? ) I wouldnt recommend doing anything...Ill rephrase that, I d recommend doing nothing!! Hope this helps.
Thanks guys. Im hoping that it will heal a bit with the next growing season, so will just leave it for now i think. If it carries on i will remove the whole limb. A bit worried that by removing the whole limb it will just bleed from there instead. I pruned it when it was dormant and i think it may not have benn a very good time of year to prune it :blushing:. Will wait until its in leaf to prune again i think. Its dripping on the guys driveway is the other problem.
"...i think. Its dripping on the guys driveway is the other problem. ..."
Pesky trees......think shigo........think water pump....."Modern Arboriculture"
Bigger wounds wont solve the issue......cheers!
I hear ya mate. Best not to get carried away and open the tree up for more decay. Will leave it and see what happens. Thanks for the advice.
