So I'm a plumber who is now verging on having an obsession with saws! On routing around in a farmers shed I found two saws both lagged in the usual farmer crap, one was a little old echo (model 315) which has no brake, gave it a strip down and it starts and runs fine, what's best to do with it I don't really want it?! The other saw was a husky 50 which I'm told is a good old saw, I done the same to that and it's now running and behaving well, the only thing is that the casing for the brake has got really hot at some point and it doesn't work,also the stop switch isn't there but I can choke it out so not worried about that, is it worth spending some £ on or not?
