windsor semi chisel chain
case mx270
Windsor chain is no longer available, so whatever is left in the marketplace is the last of it.
I note that our 73DP has been noticed a semi chisel chain with the ability to keep its edge longer due to the curve on the working corner, this also is more forgiving when filed a little inaccurate. Speeds are slightly slower than LPX full chisel but overall speed will be higher as it stays sharp longer, 3/8 058 or 1.5mm chain available from all Oregon stockists give a loop a try to see.
Oregon and Carlton are both brands owned and manufactured by Blount [as was Windsor before it was closed]
The current Blount (Europe) paper catalogue still lists Winsor chain, also bars & sprockets for the popular saws
