Thanks for all your help. I have decided to probably keep the saw as a back up or to get me out of trouble. I see on the husky guide bar that you have to grease the nose sprocket. What grease should i use??
None really, if the bar oiling is working well. If you have to, use the same grease as for the clutch bearing.
