sound about right?
Guys, just looking for opinions on this.
Does 50 cu m sound about right for approx. 60 Sycamore trees? They are fairly mature. I measured all the DBHs and a sample of heights. I'm not sure if that is acceptable, but it might be alright. I worked out the volumes using DBH, heights, and then got the tariff numbers and read off the tables.
Sounds about right to me, if you worked out DBH's, sample hieghts and used the tariff numbers and tables then your not going to be far off.
The only sure fire way of knowing is when it's on the deck / in the mill so your only looking for an educated guess. Always better to be under than over when estimating volume anyhow.
