Great 'lid' when it hot, you can fit different visor/ear defenders, my son found the visor supplied wasn't big enough for chipper work.
On your CS30/31 our tip is to find out what saws & bar you are using (if not your own) and buy a semi-chisel chain, they are much easier to do 'letter boxing' with than 'full chisel':thumbup1:
Will have a check. I'm borrowing my mates husky 346xp :D so will see what he has fitted to it.
Have a look on 'mister solutions' on their bars & chain section by model they sell 'Charlton' semi-chisel, (should be a 15 " bar). use the old chain for the workshop session but fit a new chain for work and assessment is brill. My son had to do alot of small trees so it needed to be accurate but a full chisel will jump about a bit. You will be able to put a 25" bar through with a full chisel later but for the test go for a semi only about £8'ish.
Good luck:thumbup1:
