Jensen A530 feed roller problem
conkers
You can check that it is the board by bypassing it and powering up the solenoid. If you open the box you will see a bridged blu wire with a blue wire next to it. Remove the blue wire from the far side and place it in with the bridge.
The feed rollers should turn.
You could also re set the board. At full revs,Hold the top and bottom button until the red light flashes, drop the revs to just over half and repeat the procedure holding the middle and bottom button.
I thought there must be a way of checking that by bypassing it. Thanks.
Will also check the bar control. Ta!
