Hi Im looking at lining a chipbox with sheets of OSB. It is to go onto a box section frame which is clad with galvanised sheet on the outside. I dont want to go through the sheet on the outside so looking to attach it only to the frame.
Has anyone attempted something similar, what did you use/would you recommend?
Thanks
