We are considering purchasing a new TP 175D Tracked machine.
Has anyone owned or operated this model machine ?
Any thoughts or advice, would be appreciated.
Cheers
I’ve used the TP 175D a few times but never owned one. It’s a solid tracked chipper and handles rough ground well. The feed system is strong, but it can bog down if the blades get dull. And parts are on the pricier side, so keep that in mind. If you’re working on uneven or muddy areas, it’s a good machine.
