5 hours ago, GarethM said:
https://www.redwood-global.com/wp-content/uploads/2020/04/3_6_user-manual-tr6-13-a-000-10_v1.pdf
Looks like the feed roller is secured with a screw, page 39/40.
Nice idea as a wear part, but liable to shift left/right if it's loose.
If its assembled correctly it shouldnt be loose. A bottle of loctite is your friend.
While my above advice on the bearing collar is worth looking at, also check that the feed roller is correctly located, the shaft has a dimple for the grub screw to locate in.
Screenshot_2025-06-09-22-15-04-451_com.google.android_apps.docs-edit.thumb.jpg.656132bd43f27847521757386b6985be.jpg
You dont want the grub screw to bite into the plain shaft as it will also marr it up and make it a pain to extract in future.
Edited by kram
