I'm not familiar with the brand.  When you say check the kill switch, really you need to disconnect the switch completely so you have a simple loop via the coil wire, through the spark plug and grounded by the cylinder body.
Is the gap between the coil and the flywheel set correctly - not touching and the width of a business card?
Is the flywheel OK - key not sheared off.  Is the spark plug definitely inserted into the lead properly?  Sometimes the spring cap turns around or becomes disconnected. you can check the circuit (described above) for continuity.
