Hi, i have a hakki pilke falcon 35. The previous pump did not work so i bought a new one today. But when i put it on and tried to bleed it. It did not pump. I pressed where the adjustment screw is. Does Anyone Else have this problem or a solution. ?
Edit: the pump works upside down when i tested it in the vice. So my thought is to fabricate a new fastener and mount it upside down with the oil Bottle higher than the intake nippel.
Edited by JohnTx
