Hi everyone
Total newbie to woodburning (and multifuel) here but getting a stove fitted in early Dec as I've wanted one for ages. Of course, that means I now have to decide which one to get...which has revealed just how many options there are out there. Not having any experience of stoves, it's proving a little challenging so I'm hoping someone can provide a bit of steer.
I want to get an EcoReady 2022 and Defra approved stove, which does cut down the available options somewhat, but still leaves quite a selection. I also want to go for a multifuel with an output of ~5kw. From reading around the various options, it seems that a welded steel body is generally seen as a better option for longevity...is that right? I'd also like a slightly larger window if poss (love watching the flames) so I'm now trying to narrow it down to specific manufacturers/models...and that's where it's proving slightly challenging given all the sales blurb out there!
So my questions are:
1) Stoves are often quoted as having "pre-heated air wash" (to keep glass clean) and a "tertiary air system" (to burn smoke). They both sound like a good idea but are they sales gimmicks? Or genuinely worth having? Or are these just a requirement for all EcoDesign stoves?
2) There seems to be a variance in the warranty offered between some models/manufacturers, with some offering 5 years, some 10 years and some a lifetime warranty. Obviously there's going to be a difference in quality between such models, but is there going to be a noticeable difference between a stove with a 10 year warranty and a stove with a lifetime warranty? What would be the difference be?
For example, one of the possible stoves I've found is the Arada Solution 5 Widescreen S4 (any good?)...seems to tick all the boxes and has 10 year warranty. But then there's the EcoBurn 5 Widescreen (S3), which looks very similar but is a lot more expensive (though with a lifetime warranty)
3) Are there any manufacturers that are generally better than others? Any that are worth avoiding?
Sorry if that's a bit rambling, I'm just trying to get my head round it all!
Any input would be much appreciated.
Thanks
Edited by slicendice73
