If you're just starting out and you need business, equipment, tech or training support you're in the right place. If you've done it, made it, got a van load of oily t-shirts and have decided to give something back by sharing your knowledge or wisdom, then you're welcome too.
Question
Jj_1274
Hi all
I’m in the final stages of purchasing a house in south-east London with a large oak tree (approx. 16m in height) planted 1.2 metres from the side of the house. I have consulted with both a tree consultant and an engineer and have received the following advice.
The tree consultant has advised that the tree has a remaining lifespan of c. 15 years before needing to be felled, due to proximity to the house and it’s condition.
Given the above, is heave likely if the tree is felled (I would probably cut it down sooner rather than later)? Would appreciate a few opinions on this. Would people be walking away from this purchase?
Thanks.
0 answers to this question
Register a new accountSign in
