At a standstill
TheGingerMan
So i took the cylinder off the piston head to check out what was going on in there and after putting it back on the pull i get from the pull cord is really pretty stiff, before i took it off it was doing all right for compression. Now when i do the compression test of holding the pull cord and letting the saw drop it doesn't even really drop, drops once and then no more thereafter. Any ideas?
