Hi. Have a Vermeer 935i - feed roller stopping when brush is put in. The control valve had popped a screw due to metal fatigue.Did a quick fix and pressure check. Feed rolls running but not with brush. Replaced with a non Vermeer control valve but same result. Before I spend out on a new control valve.....is the hydraulic motor worn and/or is the control valve to be a OEM??? Thanks for any info
Edited by allyear
