Hi im looking for some info to see if this is a common issue with the stihl blower 2017 bg86c-e
Problem i have is when its warmed up and i use it at 1/2 to 3/4 throttle it sounds like its misfiring , (revs up and down very fast ) very annoying to use the blower at that speed and typical that is the speed that is best to use on the blower aswell , so far no matter what i adjust i cant tune it to run perfect all the way from idle to full ,
Starts , idles spot on , and revs spot on at full throttle and 1/4 throttle revs ok ,just the 1/2 to 3/4 is the problem
Carb adjustment is per manual
its a uk model with no spark arrestor
everything is clean (air filter,spark plug )
spark plug is the original bosch from factory (only done a few tank of fuel,  its not a tool i use much )
Plug gap is set per manual
mixture is a 97 ron super unleaded fuel with stihl hp mineral oil @50:1 (i use this in my stihl strimmer with no problems at all)
anyone else had this problem ?
