Arborist Needed Bristol Council up to £10.34 p/h PAYE
CTC Recruitment
Our client is the tree section of a local authority in the south west near Bristol. The Street Care section has an exciting opportunity for a suitably qualified and climber and groundsman. The role undertakes work within a specified front line team, delivering Arboricultural services.
As part of this vital front line team you will be led by the senior arborist and required to undertake specialised tree work relating to the maintence and management of trees throughout the authority area. Both positions will share responsibility for climbing and grounds work on an equal basis giving regard to proper job rotation and strong team work.
You will require some experience and will hold NPTC CS30, CS31 and CS38 qualifications you will be competent in supporting colleagues in off ground operations and will be qualified in aerial rescue CS39 and a driving license is also desirable. The job requires a flexible approach to working hours and requires overtime and some weekend working.
Both posts will go permanent for the right candidates after an initial qualifying period of circa three months. The pay rate will be between £9.27 and £10.34 PH PAYE for a 37 hour week.
For more information please contact [email protected] or call 01743 344466 quoting reference 1702-4
