Johnleddo
Greenmech eco 150 safetrack any thoughts?
I'm on the lookout for a 6" chipper and found a Greenmech eco safetrack for sale so was just wondering if anyone has exerience òf these machines and if so what are they like? I've got a Greenmech cs100 now and have dealt with greenmech for technical help etc and found them to be very good. Any thoughts or advice would be much appreciated. Many thanks. John
Share this post
Link to post
They are a good tool, superseded by the later stuff. A good performer and well made!
Share this post
Link to post
Thanks Pete for the reply, Do you know of any re occouring problems that i should look out for? The machine im looking at is 2003 with approx 1500hrs on but thats not confirmed as the hours clock is broke.
Share this post
Link to post
Share this post
Link to post
Ring the factory with the serial number and Jade should be able to tell you who the first owner was and any other known history. They were a good little thing which I found a delight to use, nowt major to look for, just the usual chipper things. Take a lever to check for wear in the flywheel bearings, look at the shear bars, track components, function of controls, wear in the spines of both rollers etc...good luck with your purchase!
Share this post
Link to post
We've got one booked for a forestry job up next to Berwick but it won't be for two weeks - happy to report back here with our findings.
Interested to see how it copes with the tricky access between the trees and the gradient. 20% overdue thin and the brash and tops need dealing with - it will be chipping (and doing some unofficial pulling, no doubt) non-stop for three days.
It's a clean commercial site so won't give us any insight into how it copes with domestic stuff - clotheslines buried inside conifers, and the like.
Share this post
Link to post
Sounds like you've got a good test lined up for it, I'd be interested to hear how it gets on? Although I suspect that most of my work will be carried out in easier enviroments.....with the exception of the clothes lines!
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
