spandit
Supporting Swedish candle
Do the logs need to be seasoned and dry, or would fresh cut sitka work?
Seasoned wood works considerably better, dry does not necessarily matter as you burn from the inside of the log not the outside. It will take you less than 30 seconds to make one, if you cut the log from the side rather than the top down then you can use the noodles to light it.
I have used fresh cut sitka, douglas, larch, leylandii, scots, sycamore, birch & ash to make them for my own use. All burnt fine but I only use seasoned wood & keep them dry after cutting the slots if they are being sold.
Softwood burns faster works well for light/heat hardwood burns slower & is better for cooking on.
Share this post
Link to post
Oldish thread but would a ripping chain be better for cutting these?
Yes, but not really that much better.
So unless you make a great many, I wouldn't bother swapping chains especially not if you don't already have a ripping chain.
Sent from my D5803 using Arbtalk mobile app
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
