rgeparker
Fordson Major winch
Hi ROB AS you look at main side rails on the sides were engines bolted in come out from the front with weights 450)600mm on front I've some nice 56lbs weights here I used thanks Jon
Ah ok, that makes sense. I'll have to look out for some Fordson front weights then!
Share this post
Link to post
Hi mate they cost you a Arm leg mate better off with 56lbs weights on metal frame cheap thanks Jon
Share this post
Link to post
n
Sounds ideal John. Did you make up the frame yourself? Any pics?
Hi Slack Ma Girdle. That looks like a beauty! Nice wide footprint and beefy rear tyres... bet you get some good traction with that set up?
Do you find that the 3.5 tonne winch is powerful enough for what you do? Be interested to see the videos you mention.. where can I find them?
Cheers. Rob
Here's one:
[ame]
[/ame]
Here's two:
[ame]
[/ame]
Share this post
Link to post
Hi SLACK I've 7)8 56lbs weights you after them then they're good for key in the front of the tractor going to push you know tractor as a cheap £10 each cheap as chips thanks John
Posted my last reply before I saw this! Obviously, it's only fair that SlackMaGirdle has first refusal on these, but if he doesn't, I may be interested John.
Share this post
Link to post
Hi mate it easy to make just a friend coming out from the side rails just need you to channel and put the whites on the front thanks John
Share this post
Link to post
Jon has already tried to off load them on me, but i like driving around the woods with only two wheels on the ground.
If you want them help your self, just watch out that Jon :001_tt2: does not try to palm off any of his other junk.
Share this post
Link to post
Fair enough. Ill look into that then. Thanks John.
Share this post
Link to post
Share this post
Link to post
J
If you want them help your self, just watch out that Jon does not try to palm off any of his other junk.
Haha! Fair enough!
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
