Sign in to follow this
Tim Stobart Tree Surgery
Honda Mower problems
Hey all,
I recently got a spotless honda mower with a roller on it, just a wee 17" job, from a customer who has had it in her shed for a few years untouched.
It's running well, but always on the choke. Dies as soon as it's off of it, apart from a couple of times when it runs as it should. What could be causing this (it's now done 10 or so hours)?
Also, is there a way of changing the drive or gearing to make it walk faster, as it is painfully slow to walk behind? I'm sure I could just put a bigger drive cog on or something like that.
Cheers, Tim
Share this post
Link to post
I reckon it will be a 425C?
They are pretty slow, apart from upping the revs to around 3200 there is not a lot that can be done about the forward speed.
And the carb issue is typical of the Honda GC carb which is very intolerant of any contamination (give me a Briggs engine any day!). It will need a strip down, including removal of the main jet and the nozzle above it. An ultra sonic clean is advisable.
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
