Mitsubishi Canter fuso?
Czlowiek Drzewo
  • Replies 20
I've got a 3/way tipping 3.5t Canter and, as said before, it carries loads well (even with the huge high sides I put on!)
Parts are a little pricey but pattern parts are available (lamp lenses etc.). A bit heavy on the juice but mine's a double-cab and pulling a Timberwolf 190.
If you're using it in hot weather, I've found the one design fault is the rad. Not enough air passes over it and the intercooler is stuck in front of it!
All round a good, tough truck.
What does a double cab canter with three way tipper and high sides weigh? According to manufacturers spec the chassis/ crewcab alone weighs either 2255 o 2280 kgs depending on the model, so with a tipper on it and pulling a 190 TW it would suck some diesel!
