Sign in to follow this
lumberjacks
Side tipper
Hi I'd appreciate any input I wanted to mount a crane on the back of a 3 way tipping body, but would it be a disaster to try tip wood chip or move awkward 80 percent of the time
Any input would be appreciated
Share this post
Link to post
I think the occasional inconvenience of a side tip are far out weighed by the advantages of a rear mounted crane. Tipping rings off the side can be a challenge when they start rolling under the truck but other than that its no big deal.
bob
Share this post
Link to post
What kind of vehicle?
4 was is a lot easier than 2 wd as you need to drive over the tipped load most of the time.
There's a knack to it
Share this post
Link to post
It's a 12 tonne Renault Midlum with a 15 foot body
Share this post
Link to post
I have a three way tip on my cabstar, and I was going to fit a tipmaster swinglift up against the bulkhead, but was deterredbu the extra weight it adds, plus when its full of woodchip, I could see it getting jammed up round its legs
Share this post
Link to post
Must thinking of getting a 18t lorry and putting a side tipper on it as it has rear mounted crane. Are there any issues with the extra strength required on the tipping gear? Is chip spilling under rear wheels a big drama? I'd need to re- think my tip site I think...
Anyone got any good photos of side tippers in action or know ADV/disadv?
Cheers
Mark
Share this post
Link to post
The only thing I would change on the side tip mog body would be the body sides. At the moment its got a lower section as in conventional tipper sides that swing down and the upper section swings from the top of the chip box. At some point I will change this so its got a one piece side door that swings only from the top and include one of those lever release mechanisms to release it like on the tipper body below, at least you can be stood to one side when the load fires out.
Trying to knock out those normal tipper body latches and get out of the way of a timber avalanche is hard work.
http://arbtalk.co.uk/forum/attachment.php?attachmentid=177446&stc=1&d=1425117313
Share this post
Link to post
We have side tip on our mog. One piece door hinged at the top like Bob says
Share this post
Link to post
Cheers, does much of the chip run under the truck? Also does the chassis need more bracing than is required on a rear tipper?
Mark
Share this post
Link to post
Mark
A bit more chip under the chassis than a rear tip. If you are converting to a 3way or side tip you would need to make sure the pivot points are up to the job. A decent welder/fabricator would help you out. Someone with Agricultural background preferably.
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
