Dazonit
Which husqvarna
stihl 261 CM is the top of the range mid range saw,runs a 13 to 18" bar and 1.6mm chain,dont go cheap spend the money it will last you for many years also has a auto tune carb that will tune the saw to what ever work you use it for..
Share this post
Link to post
365 is ideal.
Bargain price so make sure its a genuine and check the serial number etc as the first 2 numbers denote year of manufacture.
Will do mate if he ever gets intouch cheers atb
Share this post
Link to post
It is " first generation " Husqvarna A/T on the Stihl saws .........
Share this post
Link to post
I was looking for a similar saw myself and ended up getting a Husky 365 at the APF. Brilliant saw, very light and easy to use! Go for it!!!
john441
Share this post
Link to post
only looked at the 365 on you tube and it looks like a big lump I'm after some thing the same size as the ms250 but a husqvarna
Hi
There is no comparison between a MS250 & a Husky 365, OK the 250 cuts well on a short bar and its handy when climbing but the 365 is a much better saw for firewood cutting in every aspect.
If you want a smaller Husqvarna then a 555 maybe an option but the 365 is only about 25 quid more.
I would avoid MS261s - they seem to have more than a fair share of reliability problems.
N
Share this post
Link to post
Saying you want to run a 16" bar suggests you're cutting bigger rounds. But if you like the MS250 at work, have a look at what you can do with an MS251 on 14", plus it's nice music.
Share this post
Link to post
N
...and are large and clumcy for a 50cc saw, while the 550xp etc are really neat and well handling saws.
Edited by SawTroll
Share this post
Link to post
Well herd nothing from the guy with the 365 but I think the 365 or the 550 will be my next saw I was looking at the 550 with auto tune it also plugs in to a comp and gives a read out of hours of use ect so don't no if it can be worked on and serviced at home .
Maybe The old husky 162se I'm rebuilding at the moment could be the missing mid range saw I'm looking for time will tell :thumbup1:
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
