Best rope for zig zag ?
wrighttrees
Hi all , I am currently using the zigzag mark 2 with a Yale Imori 11.7m rope. The rope seems to be a little tight and doesn't run just as smooth as I'd wish. The question is do I go for a
Tachyon 11.5mm climbing rope
Or
Marlow Aeris blue & yellow 11mm
I feel the 11mm would be better , just wondered if you can advise ,
Cheers
  • Replies 21
Seems like the 'Silky' blue tongue is a good un.:001_smile:
The tachyon has worked well for us though tbh, has had a very good bit of testing and the rope is looking fine.
Although the ZZ works well with a 13mm rope it is far better with a sub 12mm, it just depends if your climbing style will work with a thinner diameter rope.
