Sign in to follow this
Dean Lofthouse
Field repairs
Looks like it was over tightned
It does look that way and that is what the manufacturer will say, but as Gardenkit pointed out, the nut should strip before snapping the ball joint.
With castellated nut you have to be able to turn them that extra bit if needed to line up the lock pin holes. I did consider using a nylon lock nut for the new one but the holes lined up nicely with the correct torque
Share this post
Link to post
I have a ball joint kit already, but because it was the cheapo arm I didn't want to use it, the splines don't seem as tight as the more expensive one either and kept loosening every few months.
When I bought the arm last year, I bought a load of other bits, so never really took any notice of the quality or price.
Confidence is low on nasty parts:thumbup1:
Share this post
Link to post
I'm amazed how common this failure appears to be on such a safety critical component - your story on its own is terrifying, but it takes on a whole new level of seriousness when others have experienced the same failure! I'm sure there is an undercurrent of poor maintenance (not in your case) and abuse leading to a number of these failures - this component is in an exposed position and is vulnerable to off road damage - but it seems unbelievable that such an important steering component can fail with any degree of regularity.
Share this post
Link to post
my last disco sheared the pin that comes out of the steering box, minutes after doing motorway speeds for an hour! that was an original steering box leaving the vehicle with no steering at all. the scary bit was when the recovery guy said it wasn't the first he had seen like that!:scared1:
Share this post
Link to post
When I changed it last year it was horrendous, I ended up using a cordless reciprocating saw and cutting it off, this time it was easy because I copper greased the spline when I fitted the new one last year, I worked it off by hand this time
Other way is to use a plasma disc on 4" grinder, bit awkward to get it in but will cut through it in no time :thumbup1:
Share this post
Link to post
I've fitted a discovery drop arm ball joint and upgraded discovery stealing arms with a steering damper relocation kit. This gives me an easily replaceable ball joint at each end rather than the traditional defender one.
Martin
Share this post
Link to post
Steering went on Landrover today, just gone over a motorway bridge at 50 mph, pulled over, turned steering and steering just went light, main drop arm ball joint snapped. Doesn't bear thinking about what would have happened if it had gone a few seconds earlier. It was put on new last year, just goes to prove, buy cheap but twice.
Anyhow, 3 minutes an a 600mm sling got me home
Got a book somewhere called "working in the wild- land rovers manual for africa".Full of bodges and quick fixes like yours,well done dean.:thumbup:
Heh! Heh! The shortest book in the world.
Page 1: Set fire to the bloody thing & buy a Landcruiser.
Page 2 The end.
:thumbup:
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
