One kN is equivalent to to a static load of 100 kg. Therefore 22kN is equivalent to a static load of 2.2 tonnes.
The difference is that a kilogramme is measurement of mass, whereas a kilonewton is a measurement of force.
Therefore if you drop a 1 kg weight, it exerts more than 1 kN of force on impact, even though its mass remains the same.
Share this post
Link to post
:001_rolleyes:
1000N = 1KN = 98.0665KG
e.g. 22KN = 2157.463KG (2157.463KGF) = 2.157463 Tonnes
Share this post
Link to post
How is it you work out the force and or weight of an object when dropped? I know it has something to do with gravity :001_tongue:
Ie if you drop a 10kg log 10 metres what would it sort of way when it hits someone on the head...sorry the floor.:blushing:
Share this post
Link to post
10kg would drop ~9.80665m meters in ~1 second from rest
~9.80665m/sec = ~588.399m/min = ~35303.94m/hour or ~35.30394kph = ~21.9279mph
at 9.80665m drop the force of 10kg would be ~480.4595798J, if it was to stop in 1cm it would impart a force of ~4.8045 tonnes.
Share this post
Link to post
Bleedin hell nearly five tonne of force :scared1:
How did you get the 4.8045 tonne from the 10kg:confused1:
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
