Sign in to follow this
derwen
Bar and Chain for Stihl MS 250
Hi,
I do a lot of conservation work with our local rivers trust. They have a Stihl MS 250 and has been used for well over 6 years. The bar at the moment is 40cm (16"), however we have a large tree down over a river and are looking to increase the bar size to cope with the large diameter of the tree. Can anyone advise what is the biggest bar that can be fitted. We don't want to buy a bigger saw for what will be limited work. If I go to a bigger bar and compatible chain, will I need to change the sprocket as well. I have the necessary CS tickets. Thanks
Share this post
Link to post
What pitch sprocket does it have at the moment? 3/8P or .325"
The largest offered from Stihl for the 025/MS250 is 18". I don't believe any other manufacturers produce a longer one that will fit.
3005 000 4817 for 18" 3/8P .050"
3005 008 4717 for 18" .325" .063"
Share this post
Link to post
Thanks for quick reply. The pitch is .325".
An 18" bar would be fine as it gives me an extra 2".
What is the diameter of the trees? It doesn't seem worth the money and effort of new bar and chains for an extra 2 inches.
You can easily fell and cut up trees with a diameter of 32" using a 16" bar. And if you rarely have to deal with trees of that size, don't bother with the longer bar.
Share this post
Link to post
...Maybe he wants to cut 36" diameter. :blushing:
Share this post
Link to post
Thanks for trying to save me money. The problem is the tree has fallen and is across the river, with one major branch on the river bed, which is ok as it will be left to form a weir. We are looking to remove the upper branches. The majority have been cut back and now have some about 16" diameter (main limbs). The problem is I can only stand in the water upstream of the tree and cut. The water is too deep to go down stream and put another cut in from the other side. So an extra 2" would help. Unless there is something obvious I'm missing - in being able to cut 16" from one side, any help appreciated.
Share this post
Link to post
OK, I understand. If you reach over the trunk and make a cut with the bar vertical (on the far side of the trunk) first, and subsequently pull the saw towards you end proceed to cut with the bar horisontally, you'll easily cut a 24" trunk with a 16" bar standing on one side of the trunk.
Let me know if you don't follow the directions, and I'll try to post a drawing.
Share this post
Link to post
Have a look at this drawing (imagine yourself on the left hand side)...
If you reach over even further, you can cut even thicker trunks
Edited by morten
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
