Sooty Rhodies?
Swampster
Any ideas, I have been suggested a few possibilities but nothing seems certain. The client has actually 'washed' a smaller individual plant and it has not re-occured. This isn't possible en-mass and this is every-where it seems. I'm not necessarily looking for a treatment, a solid ident would be good, thanks.:confused1::confused1:
Looks similar to a fungi called Erysiphe, though the colouring looks wrong, (should be more buff-coloured).Erysiphe is prevalent when there are dry soil conditions and the leaves have been watered. Treat with a suitable fungicide, keep plants well watered and mulched, avoid overhead watering. Hopefully this will help, even if the exact fungi is not quite accurate.
PS http://en.wikipedia.org/wiki/Erysiphe
Edited by Andy Collins
Looks similar to a fungi called Erysiphe, though the colouring looks wrong, (should be more buff-coloured). Erysiphe is prevalent when there are dry soil conditions and the leaves have been watered. Treat with a suitable fungicide, keep plants well watered and mulched, avoid overhead watering. Hopefully this will help, even if the exact fungi is not quite accurate.
Erysiphe species produce whitish patches of powdery mildew on leaves and do not cover leaves totally with blackish layers, which can be washed off.
As I'm not even 100 % sure, this is a plant pathogen, IMO it would be best to identify the cause first before using a fungicide.
Oh well, back to the drawing board, it was sort of a stab in the dark anyway :biggrin:
It appears upon a little light reading I had my wires crossed somewhat. The fungi Erysiphe being a result of powdery mildew, whereas the sooty mould fungus is a non-parasitic fungus growing on leaf surfaces with honey-dew from sap-suckers Aphids etc. So control the aphids, and you control the sooty mould! I am humbled before you Gerrit :adore::adore::adore:
It's sooty mould caused by Rhododendron cushion scale. If you look on the underside of the leaves you'll see small white clumps which are the scale insects covered with a protective coating. As they grow they secrete 'honeydew' like aphids and that causes the black mould on the leaves below.
It's tremendously difficult to get rid of especially if it's widespread. You could try spraying with soft soap but it won't get rid of it completely. Systemic insecticides seem to be the only real control method.
Have a look here Cushion scale / RHS Gardening Advice
