Sign in to follow this
Busy Daddy
85k fastrac on ebay
my mate took a £120k fastrac for a demo, about 300bhp i think, he currently runs a u1600 and was thinking on changing as he cant find a good u2100 for his big timber trailer, he was very disapointed indeed, says it was great at going fast on its own but with 16 ton behind it was poor to say the least.
Share this post
Link to post
Yet another JCB product that could be sooo much better.
you could get a fendt that will outperform a fastrac for that money.
Or a huge unimog.
Share this post
Link to post
i like the old 3185 fastracs, sound good and generally pulled like a train. used to run rings round the 3220 and 3190 the firm used to have. proper hydraulic spool levers instead of the annoying electric switches that pop out of pump all the time.
downside to them is that they arent brilliant on hills and you will be constantly grabbing gears when loaded, 65kph ones were bad and the 85kph are no better. if your on narrow twisty roads with plenty of hills you wont be much quicker than a good 50kph tractor due to the width of a fastrac over a normal "big" tractor and having to bury the wing mirrors in the hedge when u meet something.. . . . but if your on nice wide roads then get it brought.
dont expect amazing off road performance from them as the 85kph one run smaller wheels than the slower ones but will still pull a few furrows when needed!
Share this post
Link to post
weve got a 185/65 65k about nearly 50mph i think - i stand to be corrected if wrong - and had no problems with it, pulls the timber trailer with a full load on now weve got new bolsters and new drawbar on the trailer had a full load of sycamore trunks on weighing 18t no probs, been carting wholecrop silage back out of very wet fields this back end and straw carting pulling 20t artic trailers no problem, the only downside is the turning circle when following the forager but theres not many big john deeres that weve had a only a bit better , pulled well and had alot of plant on the back, winches etc and chipper and not had any problems, running all night straw carting had to fill tank up and that is thirsty at about 150 ltrs i think at 50p a ltr red still not bad and our big deeres use just as much juice - particluarly like the brakes easy to get to like on lorries.
plus plent of space in the cab for a fridge box and kids
j.
Share this post
Link to post
I do like the fendts most of the ones i have seen have high hours
I am looking for a light weight , 220 +hp , suspension , and 50k speed
to run a heizohack
A lot of the estates i go to have small yards access is really bad even for the tractor i have
Any suggestions ?
Share this post
Link to post
fendts really hold their money, even more so than deeres, have a big wallet when you buy one!
have you considered a big old case, they come in still from arable farms with hardly any pto work done and just used to pull big ploughs - a consideration?
j.
Share this post
Link to post
my old valmet is in Acprices yard just now having a monster tow behind Heizo set up adapted, now thats the tool for chipping mate
Share this post
Link to post
