Great news thanks
13 minutes ago, Steve Bullman said:
Burns fine, just needs drying like everything else. If you have an open fireplace make sure you have an adequate fireguard as it woll spit
31 minutes ago, david lawrence said:
Prepare for many journeys from sofa to log basket to stove.  Burns quick
Will be ok mixed in with some ash logs?
Yes . When its green its full of water when its seasoned its full of air . All dry wood burns .
As above. It doesn't have the same energy as the same volume of say oak or ash so you will need to load the fire more often. Usually a wet tree so get it split and started drying sooner rather than later - however despite the water content when freshly cut, it should be dry fairy quickly and be ready for next winter in the right conditions (ie it sops raining).
Could try 'planting' a log see if a new tree will grow from it to replace what was cut down - fascinating to see that happen when it does.
When splitting into logs leave it in bigger chunks than you would for a harder wood.  This helps reduce the number of trips to the fire.  I guess is depends on the willow but I have some lighter wood in my stack, but then I'll take anything that burns :) If it is available and cheap then burn it.
Oh, if you leave the branches long they end to grow on the stack(!) best cut into short lengths sooner rather than later to get it dry to stop this.
Edited by Rob_the_Sparky
