Just now, turbull said:
Can you but leads from 24v  truck to 12v tractor ?
Thanks
You can but it wont do it much good .
As the man said,  connect to one battery only. You used to occasionally get away with it with old gear, but it ain't recommended!
Not tried on a tractor but these things are pretty good.
Noco boost jump start pack . They make various sizes . I have the 4250 amp one . Its about £400 but they have cheaper ones . Great bit of kit .
New battery but fit an isolator or take a terminal off, old leylands always seem to have earth leakage even with almost non existent wiring resulting in dead batteries.
Looks smaller than a 262.
Just jump start it off the car, in the old days I even started an old Leyland with ride on lawnmower left running for 5 minutes.
It depends how healthy or dead the battery is.  If its just a little low, I find pretty much any 12v car battery or booster pack will do it.  I've started all kinds of cars and a tractor with the help of my £50 400amp booster before.
If its really dead you need a strong car battery and to run the engine for a bit. Also at this stage you need a proper old fashioned power car battery charger - the modern auto ones wont work on a dead battery
