Battery polesaw
Ty Korrigan
Do you know if the motor and head can easily be detached from the shaft?
Storage/transport...
I think you would need a battery multi tool for that. I know ego do a battery multi tool.
Makita also. Not sure about husky or stihl
WWW.CLEANSTORE.CO.UK
Ego MHCC1002E Multi Tool Set 56v cordless multi-tool, 2.5Ah battery, rapid charger, hedge trimmer & pole saw attachments Ego's MHCC1002E Multi-Tool kit is a great place to start if you&rsquore lookin
I'm another fan of the Husky pole pruner.  Miles better than petrol versions that I've used, plenty power and battery lasts pretty well.  Storage and transport is an issue as it's a bit unwieldy but it's no worse than a petrol version.  I have managed to bend the shaft by dropping stuff onto it, but it still works which is something that the petrol pole pruners I've used don't always manage.
Have a look at the HTA 135, it uses the 12" 3/8 1.1mm chain as the old petrol saws did. From my limited use, it seems a good machine the motor is at the bottom as well not having a cable running up the shaft. A dam sight more heavy duty than the HTA 86 and still feels lighter than a petrol machine, probably works out the same weight but less vibration.
