What are my options?
Gav73
1 minute ago, Woodworks said:
Problem with any bricks is they wont fit neatly so wont conduct the heat away from the water tank so maybe a risk of the tank burning out? Sand clearly would make good contact with the tank. If you do use bricks the night storage ones would make a great thermal store
And fill any gaps with vermiculite beads .
Vermiculite is an insulator but you want heat to pass into the bricks when the range is fired and then pass out again as it cools. So I would think cutting the bricks to fit well and getting dry sand into the gaps would be best.
