Building Regs.
3 hours ago, Sashwindow said:
Just a quick question, when installing a new appliance ie a wood burner and new liner, are you supposed to do a pressure smoke test on the install or is a draw test acceptable. Not DIY but the professional doing the install.
Neither was requested for mine
Definitive answer is in Appendix E of building regulations Part J which is available online. Smoke test with stove and flue exit sealed and flue pre-warmed AIUI.
