Looking to get into forestry.
Donnie
Cutting wood is hard, and it's not something you can learn overnight by doing the basic tickets.  Not sure which company has offered you work, but most harvesting sites you need to have big trees, windblow and first aid + F as well.  Plus you might need to be carrying specific first aid items on your person, depending whose site it is.
Many sites are now harvester, forwarder and saw operator so there's not a lot of scope for learning from and old hand on the job.  Harvester drivers generally want trees down, fast, neat and in the right place.  Sned well if they need it and logs off as appropriate.  You have to know which machine you're felling for and what it can do.  A big machine might process a whole tree, a wee machine might need the stem run out and a log off.  Leave a tree the machine can't cope with and you'll get whined at and have to go back once he's dragged it through the muck and made a mess of it.  Process a tree too much and you'll get whined at that you're wasting time.
Anything that's easy will be done by the machine, so you're almost exclusively going to be in the really wet bits, the really steep bits, the really hairy trees or the real messes of windblow, it can also be dangerous for all these reasons.  As said above, there's times when it's too hot, too cold, things eat you, the wind is almost always blowing in the wrong direction!
All that said, it's not the worst way to spend your days and the rates are certainly beginning to move in the right direction for good, experienced cutters.  Not sure about new starts, but generally I've found guys without experience are SLOOOOOOOOOWWWWWWWWW.  Not their fault, everyone has to learn, but when there's a production element involved new guys aren't going to make good money as they can't justify it.  I don't necessarily agree that this is a good thing, but it is the way it seems to be at present.  The industry certainly needs new blood and if your long term goal is to sit in a machine then spending a few years on the saw will certainly make you a better machine operator.
Good luck.  Don't be put off by all the negatives, some days the sun does shine, there's just enough breeze in the right direction and you even get a good view.  In addition to the Chainsaw Operators Blog there's also the UK Hand Cutters page or the Forest Machine Operators Blog where you can get some good advice.
  • Like 15
You won't find better advice than this.
Wallis knows his stuff, and he is actually glazed in sitka sap 😎
If your a new operator you will probably be given the joyful job of brashing out the outsiders so machines can deal with them and carrying the jacks and wedges for the operator felling the larger ones.
Not thrilling work but it's all saw time and good to observe.
  • Like 8
Plenty of decent advise above, much of it from experienced boys who don't just have the T shirt but i'd say worn a few out, telling u not to be so daft 😀
Definately not a carear for everyone and if its for u probably something no quite right wi u anyway 😀
1 thing i will add which hasnae been said previously, and is usually an other on here's big moan about newbies both arb and forestry.
And is very easy to fix for free
LEARN SOME BASIC TREE TYPES/NAMES/SPECIES!!!!!!!!!!!!
Its not rocket science, no good having all this fancy gear if u cannae tell the difference between a spruce and a pine or native and non native ( which is quite often a spec in doing forestry scrub clearance or environmental work)
Probably even more important for arb as dealing with planted trees in gardens etc, possibly even more so down south as u have so many more tree species down there.
For forestry very important u can identify in my area ( south scotland)
Sitka Spruce
Norway Spruce
Larch
Scots Pine,  lesser extent Lodgepole pine in this area
Doug Fir, very occasional grandis
Then just a few basic hardwoods
Birch, Oak, Beech, Willow, Ash, Rowan, Sycamore, Chestnut etc
To be honest most basic tree types should be common knowledge anyway
U dont need to know latin names ( althou most planting boys will)
Just to add its very important u know and ID ur tree types so ur definately cutting doon the right tree but also they way u cut them will change from species to species.
I'd put cuts in a Sitka Spruce i'd never dream of doing with most other species even a Norway Spruce as all the fibres behave differently so hinges hold or not.
If u cant tell them apart ur in for trouble
Edited by drinksloe
  • Like 6
I'd add that one of the greatest qualities that a main contractor or forestry manager looks for in a cutter is consistency and reliability.
If I were to describe my ideal chainsaw operative they would be:
  • Punctual and reliable. Phoning in sick first thing in the morning due to a hangover, or turning up to site half pissed and an hour late isn't acceptable.
  • Steady and consistent. Knowing that you're going to get a constant work rate from a cutter is vital. There's no sense going hell for leather out the gate if you've burned yourself out at 11:00. Equally, I can't bear slackers.
  • Well equipped and well skilled. Have the right equipment and know how to use it.
  • Not be permanently skint. It's incredibly annoying being hounded for wages at 17:30 on a Friday evening.
  • Polite. A bit of banter is OK, but excessive swearing, sexually explicit talk or talking bollocks is at best wearing and at worst wholly inappropriate.
  • Flexibility. Knowing that you can ask a cutter to stay late very occasionally to finish something off is useful.
There's more that I could add to that, but that's the bulk of it.
That exactly what other forestry contractors I know say as well.
Minus the polite, nobody gives a ******** ******** ******** about that, you absolute *******!
In jest but yeah, pretty much that. Hard to find decent cutters for sure
You know the old saying jonathan practice what you preach. 😉 ( talking bollocks )
  • 1 year later...
On 20/11/2021 at 15:40, drinksloe said:
1st thing i'll say is don't it can be a real shitty job and getting worse every year, sites are often horrendous now with the big heavy machines chewing them up and the days of forwarder drivers giving u a lift up the hill are  long gone, Most dont even think to take ur stuff up the hill for u.
Some days i can barely lift my rucksack (wedges, sledge, 30T bottle jack etc plus in summer was going throu 7l of water a day, all the be carried) and then u've got to walk up a crappy site, 1km+ is not unusual.
To cap it of most foresters and more and more machine operators have not got a clue about cutting, so ur getting stupid unworkable rules from foresters who would struggle to start a saw that make no sense and machine drivers that pile produce/tops and brash at the base of trees knowing fine well a cutter has to get in there to fell it.
Or expecting u to push trees into wind against the lean/wieght.
Or phone u up at 9pm on a sun nite expecting u there mon morn? As if u just sit at home waiting on his call even thou he's known for weeks/months he was gong to ned u at some time.
When u work for an ex cutter on a machine its just night and day how the sites are set out and harvested but they are getting fewer and fewer now
Whereabouts are u in scotland??
Possibly varries locally but where i am not many cutting gangs left, althou plenty of cutting work.
Often just 1 cutter in front of a few harvesters so it is quite hard to learn and get experience of other more experienced cutters.
For years it was very rare to see another cutter on the same site as me, slightly different now as some of the companies i work for, but the old firms are still generally just 1 man
For wot ur talking about most companies will want ur basic 30 and 31 plus ur +F 1st aid ticket as a very minimum with most insisting u have the medium/large tree ticket and possibly windblow.
While spuddog know's his stuff if ur starting with 1 saw i'd saw a 50cc is just a touch on the small size for felling O/S stuff, a 60cc saw should run a 20" bar which is all u really need for 98% of trees u'll ever fell in forestry and u can rub a shorter bar on it for other jobs
. Easy handle 4ft+ butts with a 20" bar and not that often u get butts much bigger.
But it all depends exactly wot ur going ro be doing, scrub/rhoddy brASHING, respacing, 1ST THINNINGS (****************ing cAps lock doing my head in) or felling in front of harvester.
Depends on the company but some wont generally brash woods in front so u've just got the felling O/S stuff and steep bankings/gully work
Personally i like running a 50 and 70+cc saw in the van is a good combo further down the line, but the 60 sort of covers everything until then.
I generally choose the lightest/smaller saw i can to do the job as i will have to carry it all day and sned with it too so carrying big heavy saws and bars is just a bloody pain., althou u also want the power too.
That is some really good information, I am about a year or two behind JDon, who’s been helping me out with info, I’m down in Somerset, so finding operator’s willing to take you on is quite hard, but the help you get from this forum, just from reading other posts is amazing even if those giving it think it’s just off the top of their head remarks
