Wood Burner Stained
1 hour ago, Phil1974 said:
Afternoon,  was cleaning my log burner and discovered this staining on the side. Has anybody had any similar issues? Only 3 years old and had very little use.  Had the burner serviced 2 weeks ago no issue found. Thanks
Is it paint blistering ?
I got some stove polish from one of the sell-everything home shops which would work to remove that easy enough, looks like something sprayed on and not wiped off again. Looking at the hinge and the stove serviced 2 weeks ago - did they clean the glass for you? good chance it is the glass cleaning spray
