Doogle
Big Elm in Devon
7 hours ago, Beneath the bark said:
I would have said the upper right hand corner looks like it’s infected .. if you’ve had other elms around that have dies from DED then the outlook isn’t great I’m afraid .,
you can try cutting out the infected limb but I would say that 90 % of the time it ends up in removal at some stage , some of the big ones do seem to outlast but if you’ve had others in close proximity that Havnt been dealt with then it’s not looking good
The recent heatwave won’t have helped
Yes there's two patches like that fairly central and look from the ground small/isolated at the moment, there's been quite a few smaller trees around in the hedgelines that have all died and never been removed.
it seems to be fairly resilient and given it's size ita done well but these two branches have turned in the last couple of weeks.
If there's any way treatment might help then we're up for trying it
Share this post
Link to post
It’s always worth  trying By cutting off the suspect branches making sure you cut back past the staining under the bark ,
any infected limbs will
have a dark blueish sometime purple stain under the bark , easiest way to to tell is hit the bark with a hammer and peel it away , if the staining is following it’s way back to the main stem then is unlikely your save it ,
The tree that is dead next to it was also an elm I presume ?
Share this post
Link to post
The trees in the hedgerows are suckers from an original root system and are typical of the size that hedgerow elms get to before they succumb . Some of the larger much older individual elms seem to last for many years . Look at the whoppers in Brighton .
Share this post
Link to post
But if the smaller hedgerow trees are suckers/clones, then all the trees are connected via root mass below ground.
If the smaller trees have died of DED, is it not only a matter of time before the bigger trees are affected too? Will the disease not spread below ground too, it isn’t only transferred via the beetle is it?
Share this post
Link to post
Affirmative in the majority of cases
Share this post
Link to post
Did you have a very dry summer last year?
Are there more seeds this year?
A lot of the trees in Oslo look like they are succumbing to DED yet the foliage and vigour looks poor.  Yet it is a bumper year for seed production after a dry summer last year.
Could be a thought?
Share this post
Link to post
This tree looks very similar to a tree just down the road from me.  I,m guessing from the time of the original post to now it’s already to late for the tree.
DED has had a good yr in Brighton, i'. Guessing it’s to do with the national Covid holidays last yr that gave those Beatles a good head start. 🤔🙈
Share this post
Link to post
I took this pic on the 27 july. A wk later I emailed Brighton council arb. But a day later there was a DED notice on it.. so I sure there not that quick on response ding  to my email. Look at the top of the pic [1”o”clock]
Within 2 months it’s been taken down. As well as a few other trees that I’ve seen with ded. I’ve got board reporting as you would be very lucky to even get an acknowledgement let alone  of being correct…
anyhow, ive seen and reported two other trees in a similar  time frame in a woodland not far from this pic and they are still standing (completely dead) they’ve been marked up ( spray paint on the path, muddy path, now washed away) and no reply to my email)
Share this post
Link to post
This pic taken a day later (28 July), and added in with the email sent with the other tree.
I guess trees in full view at the side of the road count towards the council taking action, but using  connick tree care as they got one of the contracts
If you inquired about brightons council own arb team, you'd understand they don’t stay in the job long at 20/25k pa… it’s really a joke as we got the uk's elm collocation
iirc connick pay cir 30k pa
edit I could be wrong with the Priority of trees and who gets to fell them and the timeframe
Edited by Wonky
Edit
Share this post
Link to post
  • Tip site reviews
