Any ideas ??
Johnsond
17 minutes ago, Johnsond said:
Hi All
Long shot but wondering if any of the engineering types would have any idea what the item in the pics is. Recovered from Bristol Channel off Hinckley.
Part of a desk draw slider .
It's part of a detent locking mechanism, spring loaded ball bearing goes into spherical indentations so it can be held in different positions, possibly to hold a flap open at different positions. Used on shafts in car. gearboxes to hold gearstick in gear
2 minutes ago, petercb said:
Gearbox selector shaft mechanismpresentation_gear_box_in_transmission_system_1462305985_205162-13.jpeg
Thanks for that, few onboard had suggested something similar with the detentes but the shape at the end is throwing most. I did a job a  couple of years ago off Belgian coast and what turned out to be a B17g was identified on the cable route, we ended up with a guy onboard whom had a complete parts manual for that model and was able to confirm the identity using a retaining ring we recovered from the port wing landing lights made from non ferrous material which had survived pretty much in as new condition.
