Bournemouth Site Strip
monkeybusiness
Does anybody in Bournemouth fancy approx 10 days work stripping a site under instruction from an ecologist?
There is quite a bit of gorse to fell and remove (can be done mechanically providing arisings are removed) and also a load of brush-cutting (two passes in phases, down to 100mm to allow ecology inspection followed by a final ground-level pass).
Ideally I’m looking for a team/firm to take the whole job on - I’m after a day-rate price please.
Cheers, Dan (07970188050).
I've just sent you as text message about the job in bournemouth. I'm in the new forest so not far away.
Can the brush cutting be done in two passes of a excavator mounted flail head, or does it need to be brush cut?
I can shear al the gorse and chip with heizohack and remove from site
I’ll confirm ASAP if the first pass can be done with a flail. The final pass will be no problem I’m sure.
