4 hours ago, IJHaile said:
The zigzag has seen a lot of use, it's the new rope im returning.
Ah right.
In terms of the rope being flat, this is pretty common in new ropes when they come off the reel. Nothing to worry about and it'll sort itself out within a few weeks generally. Double braid ropes are pretty baggy and so if you can pinch it that tight along the entire length I'd say it's likely just down to the loose construction, rather than being core damage. Check the recall notice mentioned but I wouldn't be concerned about that.
Regardless however, I doubt you'll have much luck returning a used rope...
Share this post
Link to post
Seeing your pic of the narrow rope bite there and comparing to my blue tongue (bought 2014, used with ZZ2), that looks different. I would suggest contacting your supplier, see what they make of it - may be a newer, upgraded version?
Share this post
Link to post
Have you tied one end off on a tree or something and milked the rope through using a zz or a rope wrench etc to pull the outer sheath over the core a few times and re-melted the end? You might find it sorts itself out after the sheath has bedded in?
Share this post
Link to post
I'd imagine that a 6-7 year old length of rope would be much stiffer than a brand new piece. Worth speaking to the supplier but I doubt there is anything amiss...
Share this post
Link to post
Just now, twiggers said:
Really? I brought mine 10/2020? Have you further info please
Steve means the ZZ , not the rope , just in case there is anymore confusion 🙂
Share this post
Link to post
Cheers thought you meant the rope! Yes I use the new ZZ and blue T and it’s great
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
  • Tip site reviews
