Sign in to follow this
Haironyourchest
DIY Silky Polesaw
Replaced the Zubat blade recently. Attached the old blade to a ln extendable paint roller handle. Not paying 100s of € for a simple telescopic shaft.
Edited by Haironyourchest
Share this post
Link to post
How far does it reach? Must be an Irish thing, I bought a Silky Ibuki blade on ebay and a florbest handle fits on nicely.
The Bahco pruning saw is good value for money, easy enough to put a telescopic brush handle on it too.
Share this post
Link to post
I bet the paint finish is pretty shit with that . Might be ok for Artex ...
  • Haha 8
Share this post
Link to post
I used the old blade so as I don't jam or break the new blade. More likely to go wrong with a polesaw.
Reach is probably about 10-12 foot fully extended, didn't measure though. The detent (had two, one missing) failed when I started cutting, as it's an old handle. It can't take the forces of sawing, so I ripped the inner aluminium shaft right out and just used it like that, about five foot of reach. Not a true polesaw, more like a "extra reach" handsaw. Works well, way more power pull cutting with both hands. I intend to use it as an "in the tree" tool. Will buy a new 4 foot telescoping handle for it, they're  plenty cheap.
Share this post
Link to post
Sent you some Ralgex fr yr shoulders  ;) K
Share this post
Link to post
I am all in favour of diy and homemade etc but my Stihl Turbocut was worth every penny.
Being useless at climbing and scared of heights it has enabled me to dismantle some incredibly big trees from the ground.
Top marks all the same.
Share this post
Link to post
I have the wolfgarden pole with the blade & loppers attachments aint the same as the zubat in cutting though but decent quality
Also have a samurai one that cuts better than the wolf &  that fits on a  diy handle pole handle
WWW.SAMURAISAWS.CO.UK
A truly versatile product.  Add an extendable, 25mm diameter, pole and you have a high-quality pole saw featuring a top...
Seems more flex between blade and the hande though comapred to the wolf.
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
  • Tip site reviews
