Sign in to follow this
Ontario Firewood Resource
How To Operate a Log Splitter
You seem like a really nice guy however with the qty your cutting/splitting you really need a better setup.  Working on the ground with a slow splitter is not great.  Here in the uk we cut logs shorter & thinner, average length would be 9 or 10" and max width upto say what would fit in 1 hand so 6".  We also generally process hardwood.  A processor may be a investment worth having, at worst a faster & better splitter.
Share this post
Link to post
I’m lucky in that both my 10kw Stoves take 450mm and 500mm logs.
Share this post
Link to post
Is there a word missing from the title of the clip..........the word 'not' by any chance? After 5 minutes there was more physical work being done to separate the part split logs than anything else and the thing nearly tipped over twice dealing with a couple of knots! If this is how they operate and how they are meant to be operated I will stick with my axes, wedges and sledgehammers thank you.
Share this post
Link to post
9 minutes ago, frammo said:
they must have 37hr days over there if he can afford to work at that speed🤣
I think he makes the most of his money continually posting links to his youtube page on here.
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
  • Tip site reviews
