ANK
Force of a 250mm fall
Anyone know how much force is generated on the anchor point from a 250mm fall?
I know there are a lot of factors that come into play like climbers weight, but I’d imagine there have been some tests done, I just can’t find them.
Cheers!
Share this post
Link to post
Cheers!
It depends on how suddenly the falling object is arrested, if there is some flex in the system the force is less than a sudden stop.
The terminal velocity from that drop is time=0.5gt^2 so ~0.2 sec  acceleration is gt so about 2m/sev
Force on the system =mass times deceleration so the faster the stop the higher the loading
Share this post
Link to post
I guess if you jump off a 250mm wall and keep your legs locked you will feel the jolt all the way up your spine.
but it c/would be worse if your were to fall  and your harness was to stop you as you fall backwards, so that force you felt up your spine when you jump off locked legs, would be bending your back (wards) even more than it would like to go.😬
Edited by Wonky
Auto correct 🤦‍♂️Banding to bending 🤔
Share this post
Link to post
11 minutes ago, Wonky said:
I guess so. As your not ment to climb that above your anchor point
If your 250mm above your anchor point it would be a 500mm fall, just saying like.
the answer is it won’t kill you, may bruise the odd bit but nowt to panic about 🤔
Share this post
Link to post
I remember Jack Kenyon talking about this years ago, can’t remember the exact ins and outs but it went along the lines of pulling your aorta out.
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
  • Tip site reviews
