Jenson a530 track drive
A akin tree stalker
Try dig bite or some such, they might be able to help. A decent hydraulic supplier would be able to once you give him the serial number, make and model. Otherwise, give T H White a ring as the current importer!
I am sorry if this is really vague, but I was told that if there is a emblem on the face of the final drive that resembles a Citroen emblem,then it's an Italian final drive.
Either way its going to have to come out to see if the Sun gear is damaged so doing that will make it easier to match.
You are probably referring to Bonfiglioli. Although most pumps on wood chippers are from Italy.
