stuckinthemud
How? Best safe approach
There is a wind blown black poplar near me with a 2 foot diameter stem. I need some slabs 4 inch thick by 12 inch wide by 1m long (sorry about mixed measurements). My little saw only has a 14 inch bar and the section I need to cut is 14 inches off the floor, the tree is pretty gnarly, this is the only clean section. Any advise welcome
Share this post
Link to post
You won't be able to cut an accurate 12x 4 with a chainsaw with a 14" bar. You could only free hand it.
Invest in and learn how to use the right kit or as above, phone a professional.
Share this post
Link to post
There is no vehicle access, so getting a pro in is not really an option and my better half will take a dim view of a new toy, freehanding is fine by me, I'm pretty accurate with my cuts. I was thinking of separating the section I need by cross-cutting trenches a few inches wide to keep the bar from being pinched, putting a log underneath for support as the section is off the ground then once its cut through and on the deck cleaving it with some big wedges
Share this post
Link to post
Was just gong to mention exactly wot monkey had said.
Cutting windblow is 1 off most dangerous things u can do, nowadays many forestry companies have banned hand cutting windblow, even single stems even if u have tickets.
I imagine popular being brittle might be a funny 1 to cut even with experience.
Share this post
Link to post
4 minutes ago, stuckinthemud said:
I'm a carver not a tree surgeon, this is well outside my skill set
No offence, mate, but i reckon you've answered your own question there.
Share this post
Link to post
Yeah, you're right and I know it, that's why I'm on here asking questions.  The other thing I know is what I need (4inch thick slab of salix)  I haven't been able to source anywhere local to me in the past 3 years, so one lying in the woods 150 yards from my house is hard to walk away from
Share this post
Link to post
Single wind blown with root plate still in the ground is ok just take rings off until it slowly stands back up again . Multiple wind blown is a different matter . Tensions and compressions that are sometimes hard to visualize . With you wanting to cut a section out of the stem could bite you if you are not very careful .  .
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
  • Tip site reviews
