Please help identify tree
Thank you very much for the advice everyone.
I have been using a scorpion saw and axe to cut the roots. Due to the earth being very stony, the saw is blunting rather rapidly, and at £10 per blade this is an expensive problem. To solve this I have ordered online a Makita reciprocating saw as the blades are much cheaper.
For a job like this you definitely need a lot of willpower. When I've given up on willpower the stump grinder will be the next course of action.
I'm not sure what you're going to cut with a reciprocating saw without a lot more digging.  The classic digging/hacking/cutting tool is a grubbing mattock.
It would work on its own but would be easier in tandem with a crowbar for levering the rootball about.
I removed a bigger ash stump. It involved clearing the roots with a mattock to start with then cutting them with a cheap Lidl hand saw. Then I had to undermine the stump and I used one of the cheap hand picks you can pick up (Roughneck Micro Mattock). Typically there was a very big root right under the stump. At least I left 10' of trunk on the beast and I eventually winched it over.
Now I know why someone invented stump grinders.
Edited by Paul in the woods
9 hours ago, se7enthdevil said:
if it suckers as much as some people say i'd try to poison the stump first...
what have you done with the trunk?
i'm a woodturner and norway maple is a lovely timber...
I think poisoning the stump will take to long. I'm almost there now. With the help of a farmers jack and winch the stump will hopefully be forced out.
Some of the wood I will be using to make wooden border fencing for the garden, maybe some wooden coasters as Christmas presents. There are a several logs 10cm - 18cm diameter and 24cm in length that are left over. I might leave them by the driveway entrance for anyone to pick up.
it's not a durable wood so i would not make a fence from it.
as long as the wood is not going on the fire that's good news to my ears.
Mission Accomplished !
Finally finished removing the stump, very happy indeed.
During the digging process I was suspicious that some roots were growing beneath the foundations to the retaining wall. This was later confirmed when I was trying to use the farmers jack to push the stump away from the wall. I was using so much force the shear bolt to the jack snapped. As the roots were impossible to get at using a mattock, I instead used a 5 ft. chisel digging bar to break these roots. Eventually with a huge sense of relief the stump came away.
