Buel
Due to regs, hearth takes up 36% of room space?
Hello.
We were planning on adding a fireplace to our new build house but have been told that the hearth will have to protrude 1000mm in the room area by the wood burning stove supplier (for safety reasons). The room dimensions are only 4067mm x 3627mm so that's 36% of the room already taken up by the hearth!
I'm guessing that most people with fireplaces / log burners don't have significantly bigger rooms than us so please can I ask if this is a common issue and, most importantly, is there anything that can be done, or is 1000mm the rule?
Image of fireplace dimensions attached.
Share this post
Link to post
But the room is more than 4m long and the hearth is only 1.4m?  Agree with it being the order of 10% of area, but about 1/3 of width of room.  You are still left with a room width of more than 8' at the narrowest point
Share this post
Link to post
I will try and explain better tomorrow. The sofa width takes up 980mm too, you see (facing the fire).
Share this post
Link to post
Make the whole floor space hearth then it will look like you don't have one at all ! 😁
Share this post
Link to post
Building regs stipulate you only need 300mm (12 inches) in front of your stove. The deciding factor for you will be to decide how far the door opens out? Obviously you dont want ash/embers falling from your door out on to the floor. I’ll measure my hearth when i get home but it defo aint anywhere near 1000mm deep front to back, and my stove is inset to the fireplace, signed off and certified so obviously conforms to the regs or i wouldn’t of received the cert.
Share this post
Link to post
In our new build, I installed a small steel plate below the wood stove, with a suspended oak floor beneath that, probably NOT to approved specifications,
but 25 years later all I got is the odd scorch mark on the oak flooring, where I was a tad(alcohol induced) slow in lifting glowing embers.
N.B.
The wood stove is relatively long legged, so I had no concerns about excessivly downward heat.
Share this post
Link to post
I think the regs are that there has to be 300mm of hearth in front of the stove and 150mm from any combustible surface.
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
