Why does my saw die when hot?
Peasgood
The OP says the saw starts "easy" when hot which goes against piston wear or seize but agree that the first thing I always check is the compression but based on the description, sounds unlikely. You can check the bore by looking down the plug hole but needs a good LED light to illuminate the exhaust side cylinder wall.
